07 ACL and QoS Command Reference
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI[SI] Switch Series Command References-Release 2210-6W10007 ACL and QoS Command Reference
Download Book
Title Size Downloads
07 ACL and QoS Command Reference-book.pdf 641.19 KB
Preface
The H3C S5500-EI & S5500-SI documentation set includes 10 command references, which describe the commands and command syntax options available for the H3C S5500-EI & S5500-SI Switch Series Release 2210.
The ACL and QoS Command Reference describes ACL and QoS configuration commands. It covers the commands for creating ACLs, using ACLs for packet filtering, configuring QoS policies, and configuring common QoS techniques, such as traffic policing, traffic shaping, congestion management, and congestion avoidance.
This preface includes:
·           Audience
·           New and changed commands
·           Conventions
·           About the S5500-EI & S5500-SI documentation set
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the S5500-EI & S5500-SI Switch Series
This section describes by book the new and changed commands in software release 2210 over release 2208 for the S5500-EI and S5500-SI switches.
Feature module
New commands
Changed commands
ACL
rule remark
·       Keyword routing and option vpn-instance vpn-instance-name were added to the rule command in IPv6 basic ACL view and IPv6 advanced ACL view.
·       Value range for ACL names was extended to 1 to 63 characters.
QoS
Congestion management:
·       qos wfq byte-count
·       qos wfq group sp
Keywords byte-count and weight were added to the qos wfq command.
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
?WARNING
?CAUTION
?IMPORTANT
NOTE
?TIP
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-EI & S5500-SI documentation set includes:
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manuals
CE DOCs
Provide regulatory information and the safety instructions that must be followed during installation.
Quick starts
Guides you through initial installation and setup procedures to help you quickly set up your device.
Installation guides
Provides a complete guide to switch installation and specifications.
PSR150-A [ PSR150-D ] Power Modules User Manual
Describe the specifications, installation, and replacement of hot swappable 150W power modules.
RPS Ordering Information for H3C Low-End Ethernet Switches
Helps you order RPSs for switches that can work with an RPS.
User manuals for RPSs
Describe the specifications, installation, and replacement of RPSs.
User manuals for interface cards
Describe the specifications, installation, and replacement of expansion interface cards.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the specifications of pluggable transceiver modules.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Helps you deal with switch login password loss.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
